show vm-tracking repository
show vm-tracking repository {primary | secondary}
Description
Displays the FTP file synchronization configuration for NVPP and VMMAP files.
Syntax Description
primary | secondary Specifies whether you are displaying the primary or secondary FTP server configuration.
Default
If you do not specify primary or secondary, the default action is to display both the primary and secondary FTP server configurations.
Usage Guidelines
None.
The following command displays the configuration for the primary and secondary FTP servers:
# show vm-tracking repository
Primary VM-Map FTP server:
Server name:
IP address      :  10.100.1.200
VR Name         :  VR-Mgmt
Refresh-interval:  600 seconds
Path Name       : /pub (default)
User Name       : anonymous (default)
Secondary vm-map FTP server: Unconfigured
Last sync        : 16:35:15        Last sync server  : Primary
Last sync status : Successful
This command was first available in ExtremeXOS 12.5.
Platform Availability
